Big amount of data flow
The system technician says that there is too much data flow from my work pc, like i'm seeing a movie or i'm downloading something.
Actually I was connected with Team Viewer from work to home pc. Why is a data flow detected on the work PC?
    Hello @fabredolo
    This was an issue for previous minor versions.
    You need to update TeamViewer on both sides of the connections.
    You will find all the information you need in our Knowledge Base article here: How do I update TeamViewer?
    Cheers,
