Two technician licences at once - a business and a home - my home one uses the business one's concur
lefrinj
lefrinj Posts: 2 ✭✭
On my home PC I have a business Teamviewer licence for work, and I also log in as myself to help out friends and family. When I do this I switch licences and log in to get my 5 or 6 saved connections. But if I do this at the same time as someone is using or wants to use our single concurrent connection from work, it blocks one of us. I don't want to use my work connection for my 'home' computers. Is there a way to stop that from happening? Thanks.
  • Ying_Q
    Ying_Q Posts: 2,598 Moderator
    Hi @lefrinj,
    If you would like to discontinue using TeamViewer Business license on your home PC, kindly check out How to deactivate (remove) device from the Business license and do not login the licensed account on your home PC again. It is recommended that your have a separate personal account and purely uses for personal connections.
    Hope the explanation helps and let us know if you have any other questions.
    Community Moderator/中文社区管理员
