Teamviewer QS android for personal use?
Does TV QS require a paid license to support family or firends Android device? When I connect to my family members Android phone, QS seems to timeout / disconnect after 5 minutes.
  • Ying_Q
    Ying_Q Posts: 2,596 Moderator
    Hi @ptwilli1
    Thank you for posting.
    If you are interested in purchasing TeamViewer license, feel free to contact TeamViewer sales team for more information please.
    Or you may try submit the form for TeamViewer ID reset if you think TeamViewer has mistakely marked your device usage. Once reset is done, the time limitation on connection will be removed.
    Hope the information above will be helpful to you.
    Community Moderator/中文社区管理员
  • ptwilli1
    So based on your reply, it seems you can use TV QS for personal use. Is that correct?
  • ptwilli1
    Can anyone confirm if a paid license is needed to use QS more than 5 minutes?
