Lock remote screen size on 4k monitor
I have a 4k monitor where when I open a remote computer (1920x1200) up on it, it comes up small so I have to adjust the window size to be it bigger by scaling. Is there anyway to save this size so I don't have to manually make the window bigger everytime I log into a remote PC?
Hi @fitnesspm
You could store the remote resolution in your computer & contact list as follows:
Open the properties within the gearwheel
On the left you will find the advanced optionsHere you make the setting for View Settings --> Remote resolution
I hope this is helpful.Cheers.
Reyhan
Reyhan0 -
I've already been looking in those settings but nothing helps. The window for the remote connection is 2 small (1920x1200 and I have to scale it to make it bigger. How do I automatically set it so it's bigger everytime on my 4k monitor?
So there is no option???
