using teamviewer commercial on non commercial
hi
we have a license for commercial use for the company i work for, if i want to manage computers in the business can i use non commercial on those computers so i can manage them or do they need commercial licensing aswell to be managed
  • JoshP
    JoshP Posts: 858 Senior Moderator
    Hello @Pascalde
    With TeamViewer, only one side of the connection needs to be licensed. As long as you are connecting using your licensed account, it would not matter which version was installed on the devices.
    We recommend you create a custom Host module and install it on any devices you will manage. This ensures your devices are always accessible to you and your team.
    Hope this helps!
    Josh P.
    Senior Community Moderator
  • hi
    thanks for the quick answer, also if users by chance would use it lets say from home and connect to office,, not that anyone as but would that be a breach
