remote access - poor internet
hi - I use TV to access a dozen or so PC's located at remote hydro geenrating stations , unmanned small power stations.
On some the iternet connection is not good .. and in some cases TV says PC is online but will not establish a connection. **Third Party Product** will extablis a connection.
There are several links in chain of internet connection - 4G to network over power cable adapters, so probably quite a delay end to end.
Any ideas of ways we could get TV to work reliably on these sort of poor connection sites ?
Woudl really liek to give up on **Third Party Product**.
    Hello @morbenhydro
    There are two parameters you can test and play with.
    • Deactivate UDP
    • Disable hardware acceleration
    I recommend you to test by disabling these options and see what settings fits better to the machines with poor internet bandwith.
    Cheers,
