Can you fix your installer (v.15)?. I am trying to update over 5k machines, but your **bleep** installer can't remove older versions, and the older versions (v14) uninstall function doesn't really do anything. If I have to script away your malware v.14 on 5k machines; I'm out. I can put up with the admin console quorks, and idiocies, even the --grant-easy-access catastrophe,  but when your software doesn't do basic things like install, or uninstall, we are done. How's this suposed to work for an enterprise? **third party product** it is then.
