Teamviewer 14.7.1965 does not start on Ubuntu 18.04 (x86 32bit)
Teamviewer crashes on start with segfault in libgcc_s.so.1 while trying to show "Lizenz  Abkommen" window.
Start sequence:
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
Speicherzugriffsfehler (Speicherabzug geschrieben)
syslog:
TeamViewer[7136]: segfault at 42b60000 ip b1bc1f7e sp bfc91ca0 error 4 in libgcc_s.so.1[b1bae000+1c000]
  • Thossi
    Thossi Posts: 2 ✭✭
    After upgrading from Ubuntu 18.04 to 19.10 I am getting exactly the same error message. Is there any resolution available already? Btw, Teamviewer was running fine before the upgrade!
    Thossi
  • Thossi
    Thossi Posts: 2 ✭✭
    I think I found the issue:
    My PC is working with a NVIDIA graphics card and after deleting the graphics driver and re-installing it, all is good again. By the way, my system is a amd64 bit system. In general it is strongly recommended to de-install the nvidia driver BEFORE upgrading to a new Ubuntu version (which I did not do this time).
    Hope this helps anyone that is getting the same issue
    Kind regards
    Thossi
