As a follow-up to our Statement on Recent Post - CVE-2019-18988 regarding the encryption of TeamViewer registry keys, we would like to again clarify that TeamViewer account passwords are not affected as we use Secure Remote Password (SRP) for account authentication. The issue discussed in a blog post by a security researcher concerns the local data storage and encryption of the TeamViewer client as detailed below. In order to take advantage of the issue, someone would need to have already gained access to a user’s system via other means.
What is it not?
TeamViewer account password encryption has not been compromised. TeamViewer implements Secure Remote Password (SRP) for account authentication.
In the blog post, the researcher mentions a privilege escalation risk. There’s no direct vulnerability offering someone the ability to gain additional privileges on the local system. The only risk would be in the case that a user is reusing the exposed passwords on other services.
What is it?
In the blog post the researcher discusses the encryption of certain Windows Registry entries, which may include the TeamViewer client settings-password that is used to restrict configuration access. Additionally, these registry keys can hold temporary information used only in specific TeamViewer client deployments as well as for the TeamViewer license and statically configured session passwords of legacy versions. The blog post also refers to some unused registry keys.
What does it mean?
As this is a local exploit, in order to take advantage of the issue, someone would need to have already gained access to a user’s system via other means. In this case, someone who manages to decrypt the registry entries in question would gain access to:
- The client settings-password that allows administrators to restrict user access to the configuration panel of a local TeamViewer instance. In most cases, this password is not implemented.
- A statically configured session passwords for TeamViewer version 8 only. By default, this feature is not used, but our dynamically generated password that changes with every session. Versions older than TeamViewer 8 are affected as well but will be deprecated by the end of this week under a separate initiative
- The password for proxies configured in the TeamViewer client. This is used only in unusual instances as TeamViewer does not require a proxy configuration in most environments. A use case for this setup is for companies that chose to have a custom proxy specifically for TeamViewer.
- The license key for the installed TeamViewer client on a perpetual plan. Perpetual licenses are all versions prior to TeamViewer 14. TeamViewer 15 licenses are subscriptions which do not use this registry key.
The remainder of the registry entries are used only during deployment process and are automatically cleaned up afterwards.
What are we doing?
Our security engineers are working on concrete solutions to mitigate the researcher's findings such as further improving the encryption for the data points that need to be available on the local system.
The changes will be centered around improving the security and limiting the use of local registry keys. There are certain values that need to be stored locally for the usage of TeamViewer. As the client has changed over time through major releases, some of those are still required while others make sense to store centrally or deprecate out of the product.
Here are the 7 registry keys discussed in the researcher’s blog post:
SecurityPasswordAES
This registry key is only valid in TeamViewer versions older than TeamViewer 9. By default, TeamViewer utilizes a dynamic password system that generates a new session password with each session. For those users who chose to set a static session password in order to support unattended access, that value is stored in this registry key. Since then we introduced an option called easy access, based on the account authentication and inviting the user to distance themselves from using a static password which can be weak, re-used from somewhere else, guessed, etc.
Planned Fix
Strengthen the cryptography. Adapt the storage/verification to a more modern method.
SecurityPasswordExported
This registry key is used for cases where users chose to export their configurations in order to make it portable to other systems. It is important to note that this key is an ephemeral value that is only existent during the export/import of a configuration.
Planned Fix
Strengthen the cryptography. Change export file type to something other than .reg so that users don’t mistakenly import this value permanently into the registry.
ServerPasswordAES
This registry key was added to the client as preparation for an unimplemented backend feature. It is not used.
Planned Fix
Remove the key from the client.
ProxyPasswordAES
TeamViewer has quite a few methods of reaching the internet that make it easy for users to use the product in a large variety of network configurations. Be it TCP, UDP hole punching, over HTTP ports or by inheriting the local systems proxy configuration. Sometimes customers chose to set up a custom proxy just for TeamViewer, and in those cases, we store a password for that proxy configuration in this registry key.
Planned Fix
Strengthen the method used to read the value. This entry would only be considered if the service is running which allows us to use a strong cryptographic model.
LicenseKeyAES
This is the license key for TeamViewer clients installed with a license. The registry key only exists until the client registers with our servers; after that it is deleted.
For newer versions of TeamViewer (some v14 and all v15) the license is under a subscription model that is tied to an account authentication. The registry key is not used in these cases.
Planned Fix
Remove the key from TeamViewer 15 as it is not used in that version. Legacy versions still need to support that temporary entry, given the former licensing model.
OptionsPassword
As with most client applications, the TeamViewer client is open to configuration by the current logged in user on the machine. We offer the option to lock those configurations with a password. This is usually used in deployments in larger environments to help IT administrator preventing any alteration of the configuration.
Planned Fix
Change the way this is handled cryptographically.
PermanentPassword
TeamViewer implemented the Secure Remote Password protocol for authentication starting with TeamViewer 9. This key is used to store the SRP password verifier as part of that protocol.
Planned Fix
No fix needed, works as intended. Not vulnerable.
Natascha
