TeamViewer Host on Android not starting
Hey all, I’m running TeamViewer Host on a Lenovo tablet, and after the tablet starts, I’m unable to connect.
I can see it in the management console, but when I try to connect it says that TeamViewer isn’t running.
    Hello @DJQuad
    We recommend you to uninstall the Host and to reinstall the latest version from the Play Store or from our website. And to try again, to see if the issue persists.
    Cheers,
  • DJQuad
    TeamViewer or TeamViewer Host? I do need unattended access.
  • DJQuad
    Yesterday I reinstalled Host and was able to connect, however today I cannot.
    Hello @DJQuad
    If the connection on the remote side is stable and working, it should work fine.
    Have you checked the connection on the remote side?
  • DJQuad
    Yes, the connection is fine. It's able to access the Internet (Chrome, Gmail notifications, etc)
    I see. And are you sure that TeamViewer is running on the remote device?
    Do you have the device in front of you and did you click on the TeamViewer Host to run it?
