Paytm Android App asking to uninstall TeamViewer
I am located in India and have teamviewer installed on my Android mobile.
Recently another app Paytm has started asking users to uninstall remote control apps from their mobile.paytm_issue.JPG
How to come out of this error?
Is there any way to bypass this in paytm.
I do not want to uninstall either teamviewer or paytm.
  • Yuri_T
    Hi @rupeshk ,
    Thank you for raising that up.
    We have reached out to PayTM to clarify why they are forcing their users to uninstall TeamViewer. At this stage, we are not able to change it from our side, therefore please contact PayTM regarding this case.
    However, please note that we provide legitimate software that helps millions of people to support others with device problems. TeamViewer sessions are end-to-end encrypted and we adhere to the highest security and privacy standards. Please make sure to only allow connections to people you trust in.
    Hope this information will be helpful.
    Kind regards,
    Yuri
  • jkRupala
    hi
    i have made small tutorial how to solve this problem.
    https://youtu.be/PTqOB3e5g0Q
    cheers
  • snathpatil
    I had contacted PayTm and this is what they replied -
    Hi! It is the security feature designed to prevent the frauds. This feature help prevent fraud by not letting fraudsters using these apps.
    I have now reported this to Google play store content violations team as well. Lets hope this gets resolved.
  • jkRupala
    The earlier Video didn't work properly
    This will work 100%
    https://youtu.be/ny5hhrkhQBc
  • Satheeshvarma
    There is a easy workaround to this problem. Just type the Paytm care link in browser. https://m.p-y.tm/care
    The page will ask you to go to 24x7 help section in paytm app. Click that link. Now paytm app opens with the page for raising tickets. Now press back button and use the Paytm app normally.
  • rupeshk
    rupeshk Posts: 2
    Even this suggestion is not working even after uninstalling teamviewer.
