Set TV Host 14 password on remote computer
How is it possible to set the access password for TeamViewer Host 14.1.3399 on a remote computer without having to set the password manually in the gui? The only thing i could find after hours of searching the web was exporting and importing the Reg Key "PermantentPassword" under HKLM\Software\Wow6432Node\TeamViewer. Sadly this dos not work. Sometimes it accepts the password change but after the teamviewer service gets restarted the password is gone and some other random key is set in regedit.
I am sure there is a solution for this. But somehow i can not find a way.
Find more posts tagged with
Hi Vatsilidis,
no, i want to change the unattended access password set on TeamViewer Host via Powershell or something similar from a remote computer.
We deploy multiple TV Host installations per day and we do not want to change the password by hand every time because this takes up a lot of time! There must be a different way!?
Do you want to store the remote computer user account credentials for permanent access?
If yes, then please take a look to this post. It is very easy to be done.
If this helps you, please let me know.
Best regards
Did you ever find a solution?
