Do i need a business licence for iphone screen sharing?
I am trying to help my parents who have just received new phones to set them up correctly.
They both live in another country so I can't just pop round.
They have managed to install the QS app and I can connect without screen sharing no problem.
as soon as I try to use the screen sharing part it tells me I need an add on.
when I click through to try to buy the add on nothing is available.
I don't mind paying for the service if it is going to work
anyone had this?
Thanks in advance
Tom
  • Vatsilidis
    Vatsilidis Posts: 655 ⭐Star⭐
    Hi @Walshie11
    DO you guide your parents to adjust the settings on their phones, as they appear to this post?
    Probably applying these settings will give you the result you want.
    Best regards
  • thanks for the reply,
    they have followed those guidelines exactly, and I can connect to the device without screen sharing
    this is the pop up I get when I try to use the screen sharing id.
  • then when I click on buy now, there is nothing available to purchase
  • Vatsilidis
    Let me transfer this to a Moderator and see why does this happen to you.
  • Vatsilidis
    Have you already look at this post about the app purchase on iOS?
    Could you try it?
  • Vatsilidis
    Hi @Walshie11
    I found what's happening!
    Please take a look at this post and scroll down. You will see the same message and the answer of Esther (community manager) on this.
    I hope this solves any worries that existed! In another case, please let me know.
    Best regards and take care
