I need to add near 120 computers to control to my teamviewer, so i am woundering if i can export / import a list of my contacts so i can do this task a lot faster?
Hi @Big-Bambino53
I think, the TeamViewer Integration "User Management" will help you.
Please find more information on our Integration site.
Feel free to post an update here to inform the other Community members about your experience!
Thank you in advance,
Esther
An issue since 2017, yet we still need to jump through hoops & run powershell commands, just to achieve the most necessary & simplest function
After a few weeks of trying to get the import to work, finally had a win, all 200 devices imported into Teamviewer successfully
format your CSV file as below
Device Name
TeamViewer ID
Group ID
Laptop01
xxxxxxxxxx
gxxxxxxxxx
Create your API with the below permissions
Group management
Read groups
Computers & Contacts
View entries, add entries, edit entries, remove entries
Powershell :-
$apiToken = "INSERT_TOKEN_HERE" $teamViewerApiUrl = "https://webapi.teamviewer.com/api/v1/devices"
$devices = Import-Csv "C:\tmp\teamviewerDevices.csv"
foreach ($device in $devices) { $deviceName = $device.'Device Name' $teamViewerID = $device.'TeamViewer ID'
# Add the 'r-' prefix to the TeamViewer ID $formattedTeamViewerID = "r-$teamViewerID" $groupID = $device.'Group ID' # Create the request body as JSON $body = @{ alias = $deviceName remotecontrol_id = $formattedTeamViewerID groupid = $groupID } | ConvertTo-Json # Define headers with API token for authorization $headers = @{ "Authorization" = "Bearer $apiToken" "Content-Type" = "application/json" } # Make the API call to add the device try { $response = Invoke-RestMethod -Method Post -Uri $teamViewerApiUrl -Headers $headers -Body $body Write-Host "Device $deviceName added successfully." } catch { Write-Host "Failed to add device $deviceName. Error: $_" }
Hello all,
To export the computers list, please check the instructions here:
To export the user list, please check the instructions here:
/JeanK
Hi!
I have read the above thread, and have the excact same issue.
Any news regarding implementing Import / export of contacts/computers ?
Should really not be so hard to ad this feature to Teamviewer, and it would be a great help to users !!!
Regards Leif Bryde
Hello everyone,
I have followed the link [ Integrations - User Management ] which was indicated a few years ago (2017 and 2018) by Esther and I agree with PeKa:
It absolutely does NOT answer the question
For my part, I need to import 225 users which all 4 of our technicians will be asked to help in the future.
The question is simple: IS THERE A SIMPLE WAY TO IMPORT INFORMATION FROM A .txt or .csv FILE INTO TEAM VIEWER ?
It's a simple «yes» or «no» question
User Management API? PowerShell? Seriously? Really? In software that costs so much money? Instead of adding some nonsensical functions maybe you could finally add this functionality?
Or maybe you have already done it and it can be easily done?
Hi there,
I have a little problem.We recently acquired a company that uses an old team viewer (8).There are 100+ devices in this team viewer.
We also use a team viewer ourselves but use a new license (Coporate)
How can I transfer the devices from the old environment to our new environment?
Regards,Hendri
Hey,
What is the best way to export devices list from one user to another ?Thank you so much :-)
Hi @crozzle
Thanks for the hint.
I updated the link in my previous post and it works again:
Best, Esther
See what's new at TeamViewer
