Transfer File from macOS USB disk
MCAN
TeamViewer All Transfer File do not work : From a recent macOS USB (external disk or key) to another remote machine. macOS Catalina version 10.15.4 (MacBook Pro 15-inch, 2018) TeamViewer 15.4.44445 Message : Une erreur est survenue avec le fichier "volumes/MeIC/temp/fic.pdf". Erreur : (2)2 The Authorization was Correct (Sécurité et confidentialité) Vérification des accès au système (3 Green) Autorisé
m'a
I have already do this : https://community.teamviewer.com/t5/Knowledge-Base/How-to-control-a-Mac-running-macOS-10-14-or-higher/ta-p/44699 the transfert from local disk work fine (but not the USB ...)m'a0
Hi @MCAN
Have you tried first to copy the file to the Desktop of macOS and after to transfer it to the destination?
I know it sounds strange but could it be some reasons that could make this issue appear to mac.
Best regards
