TeamViewer 14 does not work on mac os El Capitan?? can't start. constantly crashes.
Thanks for all your reports and help in identifying this issue.
Our developers created a fix for it and we would need your help to test it. It would be great if you could download the fixed version from this link and test whether it solves the issue for you.
We would appreciate your feedback so that we can publish the version as soon as possible to everyone.
One of our findings is, that the issue appears on old hardware. Can you confirm?
Thanks, and we are looking forward to your feedback,
Esther
I would guess your solution should work. I know.
But No. I have run appcleaner and deleted all files. and even looked in library/prefs etc. manually to delete everything.Restarted several times and made a clean install with the TV 14 dmg.The app keeps crashing right away after installation and keeps crashing every 2 seconds.It's pure horror for me now.
use appcleaner. its free. (The URL link has been removed by a moderator)
I just downgraded to TeamViewer 13 on all computers again.TV14 does not work on El Capitan and lower, and is not compatible with TV 14 or vice versa.So no more tv14 for me.
Well, really nice it works for you. But for the rest of el capitan users it does not..
Same over here! Unabable to get TV 14.1.3399 working onmy iMac with El Capitan 10.11.6
Have try and buy App Cleaner & Unninstaller, no succes... Then buy the PRO of App Cleaner and same result (
Same problem here. TV 14 crashes instantly upon attempting to launch on El Capitan.
I downloaded today's version (14.1.3399) since there was some release notes from a couple of days ago but still same problem.
I manually deleted previous version (including Library files) but it didn't help.
I get the dreaded error message EXC_BAD_INSTRUCTION (SIGILL)
Hi @LordBBK
Thanks for your feedback! It is great to hear that the version fixed the issue for you!
I informed the devs immediately about it to share the good news, and they are looking forward to receiving some more feedback from the others.
Thanks again and happy holidays,
Same for me !
Version 14.7.48671 for El Capitain on iMac 2009, updated to 15.2 by Teamviewer ( by the way 15.2 is not available for direct download from teamviewer ). Starts up, but I cannot link to this device with any Mohave OsX or vice versa. I get the message " the linked computer run an old version, update " but there in no further update for the El Capitain !!! It is really a big drawback if we cannot link to older computers, there are millions of them still running.
