TeamViewer 14 mac on El Capitan???
2»
  • Same for me !
  • mzmzmzmz Posts: 1
    imac mid 2007 - the prepared version for older hardware works perfect.
    Thank you Teamviewer to keep an eye on old hardware.
  • Thank you so much. This will help me to solve my issue.
  • you link is not valid.  Please correct it so that I can download it
  • LordBBKLordBBK Posts: 3
    Dear Joylaptop,
    I suppose that they have merged the patch into the master version of TeamViewer, so if you would download the current version it shall work. The link was not mine just quoted the message received from the support.
    Sincerely,
    BBK
  • I have run app cleaners and deleted all files. and even looked in library/prefs etc. manually to delete everything.
    Restarted several times and made a clean install with the TV 14  dmg.
  • CoryCory Posts: 2
    Same problem with MacOS Mojave
    Tablio
  • OUROUR Posts: 9
    It doesn't work as you say.
    Even after Multiple removes and s=installs.
    Go back to an older version ...13? or 12? :-(
  • I have downloaded the latest version of Teamviewer on Mac OS Mojave and it still immediately crashes. I have un-installed and re-installed 3 separate times now. The first time Teamviewer worked for a day or so before it started crashing again.
    I also downgraded to Teamviewer 13 and it still crashed even though it was previously working.
    Mojave is 10.14.6
  • EricK67EricK67 Posts: 1
    Hi  I also need urgently a version working fine with EL CAPITAL  10.11.6     Do you have  a link to share  for downloading that version of TEAMVIEWER ?
  • EstherEsther Posts: 2,991 Community Manager
