connection not possible to remote PC
<PC> has signed in message on screen, but if I try to connect to the remote PC message "A connection couldn't be established. Teamviewer is not running on remote PC appears.
Any Ideas
Teamviewer 12 on both
  • bartlanz
    bartlanz Posts: 315 ✭✭✭
    On the remote PC, does TeamViewer say "Ready to Connect" on the main screen?
    Bart Lanzillotti
  • GiancaGentile
    Check if you have "easy connect" enabled (I'm not sure about "easy connect" because I use a portugese version, but it's a acceptabel translation...)
