Windows 10 can't find TeamViewer
Today, clicking on the TeamViewer icon on my Task Bar started producing the following error:TeamViewer Error.jpgI've uninstalled and re-installed TV. Even going to the actual .exe file in the Windows Programs folder and double-clicking that produces this same error. I'm not sure what the reference to Internet Explorer is about. I don't have IE installed on my machine any longer.
  • mattdocmartin
    Tried calling support, they said check here. Found this thread, no answers
  • mattdocmartin
    Solution:
    Go to:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
    delete the key labeled "teamviewer.exe"
  • mattdocmartin
    I then reinstalled and i worked!
  • mattdocmartin
    Let me know if you succeed
  • Pstreicher
    @mattdocmartin wrote:
    Solution:
    Go to:
    I gave you kudos for this. I was able to use Regedit and find the offending keys and delete them. Upon reinstallling Teamviewer it now works again. Thanks so much!
