Changing ID with every start
After Updating from Windows 7 to Windows 10 Teamviewer changes the ID every time I start the computer. When I login with my account then I have to confirm each time the link in the email. Also I cannot connect from remote because the id changed.
Let me confirm, Is the "Your ID" changing or the Password?
Bart Lanzillotti0 -
Your ID
Did you install TeamViewer as an Administrator on that computer? That ID is usually stored in the registry I think. The only reason it would be changing is because it is unalbe to be stored.
Bart Lanzillotti1 -
The account has admin rights, but I did not explicitly start the setupt with right click "as administrator". Should I do that?
Or: Where is the id stored? If I know I could try to change the permissions.
I changed permissions in the registry of HKEY_LOCAL_MACHINE\Software\WOW6432Node\TeamViewer to Everybody full access, but the problem ist still the same.
