can't control remotely my android
ladytf
ladytf Posts: 6
I'm sorry, i'm terrible in my english but i will try...
I can't acess my phone remotly. i already try with qs app and the host app.
I press the option allow on my phone and in computer keep saying "tyour partner rejected your connection request"
what i can do?
i have a ulefone power 3s
  • Esther
    HI @ladytf
    It sounds like you will need to ask the owner of that phone to accept the TeamViewer connection. As the notification states: Your partner (the one holding the phone) rejected your connection request.
    There should be a prompt on the screen and s/he should accept the request to allow you access to the phone.
    Esther
  • ladytf
    ladytf Posts: 6
    hi @Esther
    the phone is mine, i give premission...
    Exist a permission hidden somewhere?
    i have my phone and computer in portuguese but i can send pictures if i think that helps
  • Esther
    Hi again @ladytf
    Is your TeamViewer on your mobile and your computer running with the latest release?
    Did you already restart both apps?
    Best, Esther
  • ladytf
    ladytf Posts: 6
    yess i have
    a few weeks ago i had do the control remote, this week i try and cann't do...
  • Esther
    OK - if you are on the latest release and already restarted the service, there is not much you can do.
    As the last question: How much time passes between you send the prompt to the mobile and you click the Accept  Button?
    Esther
  • ladytf
    ladytf Posts: 6
    almost immediately. i have my phone next to me
  • Esther
    Hi @ladytf
    Thanks for getting back to me.
    In case you have a TeamViewer license, I recommend contacting TeamViewer's technical support and sending in the logfiles both from your Android device and your computer for a deeper analysis.
    In case, you are a free user and can´t send in a ticket to the support, my recommendation is to make a fresh install of both apps and try again to connect. Maybe we also find another community user, who had the same issue and found a solution.
    I am keeping my fingers crossed that you will find a solution quickly!
    Esther
  • ladytf
    ladytf Posts: 6
    with teamviwer host is needed some premission after insert the e-mail account?
  • ladytf
    ladytf Posts: 6
    i unistal every teamviwer on my phone and instal just android host.... the problem continues....
    when i enter from teamviwer host he doesn't ask me for any permission... is normal?
  • kelk10
    kelk10 Posts: 1
    I had this issue on quicksupport.  I fixed it by going to Setttings>Apps>QuickSupport  and turning "Appear on top" to "On"
