I can’t delete the old compute ID and add a new ID
eronryabets
Posts: 1 ✭
I I changed Windows, and now I can not log in
1
Hi @eronryabets,
I’m sorry to hear about the issue you were experiencing.
As the language showed in your screenshot is not English, unfortunately we couldn’t identify the exact error message.
To help you find a solution ASAP, I would recommend creating a support ticket with the required information.
Alternatively, you can contact our support directly, they will be able to help: https://www.teamviewer.com/en/support/contact/.
I hope the information above would be helpful!
Fiona
Fiona_G0
