No Sound on Android from Windows 10
Alitai
Alitai Posts: 18 ✭✭
Hello Together
I have a Samsung Galaxy S8 (Patch Level: 1. October 2017, Android Version 7)
Windows 10 1607 is installed on 2 PCs (With Patches from December) and TV 13 installed. I connect from the Phone to Windows over the IP in the same Network.
On both Tests i can't get Sound on my Phone. On the iPhone all works. The TV Android Version is 13.0.8183 CL.
I have no idea what's the Problem is.
Has anybody the same Problem?
What i will try now, is to install Windows 10 1709.
Edit:
- Windows 10 1703: Same Problem
- Windows 10 1709: Not my Client but same Problem
- TV 12: Same Problem with Windows 10 1607
Edit 2:
- Over the normal TV ID it works but not over the IP-Address.
- Tested also with 2nd Android Smartphone but no luck.
@support-Team: Can you have a look at this (Reproduce it)? I'm out of ideas. Mabye it a Problem with UDP/TCP.
Many Thanks
Best Regards and a Happy New Year.
Alitai
  • Alitai
    Alitai Posts: 18 ✭✭
    Hello
    I found a Workaround that's working for me.
    Alitai
  • jonjuk
    jonjuk Posts: 1
    What was your workaround? I'm also having the same issue..
  • coestric
    coestric Posts: 3
    Me too. I have the same issue.
    Could you please post the workaround.
This Week's Leaders
