Advanced Options Graphic/Layout Issue
There is an issue with the Extras-Options-Advanced page. If you scroll to the very bottom you will see the Export and Import buttons and just the top edge of what I believe is the Save As button. The rest of this button and it's associated text is burried behind the windows border with no way to scroll any lower.Advanced Options Issue.JPG
  • Weatherson
    Weatherson Posts: 2 ✭✭
    Thank you Fiona. I'll wait for the next update.
