Windows Game Mode menu not visible in remote control
When i used my android phone team viewer to remote control my home PC with Windows 10, everythign is working expected.
However, when i select the screen keyboard by pressing 'Windows Key' + G to enable Game mode in remote desktop/PC, I can't see the menu on my Android phone. But remote desktop/PC game mode menu does appear. It seems Teamviewer can't capture this part of the menu and reflect on the remote control screen?
Any kind soul has any clue? Thank you very much!
    JeanK Posts: 7,052 Community Manager 🌍
    Hello @kohay
    The game mode in Windows uses a specific background surface that TeamViewer on Android can't capture.
    There is, unfortunately, no workaround for this. ?
    Best regards
  • LeSade
    LeSade Posts: 1
    It still happening?
    even from another PC i cant see it.
    screen share at discord / zoom / teams do capture that.
    only on teamviewer i cant see this game bar menu.
