Announcements
Here you will find the download links for all modules
in version 9: TeamViewer 9
Posted by Toolix
Photon
Connection to remote host stops at statusinfo initialize display parameters
Dear all,
while connecting to a remote host via TeamViewer the remote Windows 10 displayed some information about parameters for the Windows 10 Creators update, that should be defined. I'm currently not planning to install this update and thus tried to cancel this info screen. As this wasn't possible I ended the TeamViewer connection and tried again. Since then I only receive "initialize display parameters" while trying to reconnect again. Do you have any hint to e.g. reset the remote TeamViewer?
Thanks in advance and best regards
Michael
