How long does it takes to re-add the same user/email after being removed?
Announcements
First Step Guides
  1. Are you new to TeamViewer and Home Office and need some help? Check out our FAQ here.
  2. New to the Remote Access Plan? Find our first steps FAQ here.
  3. Are you new to blizz and online meetings or classes and need some help? Check out our FAQ here.
Highlighted
Posted by
Henagon
User lost the activation message, hence (as admin) I have removed the user and hope to re-trigger the activiation message by re-adding... user account removed and now I am block as system report email-already-in-use.... how long does it takes to refresh? or what need to be done to re-add the same user or simple resent activation links. Thx
Highlighted
Posted by Former Staff
Former Staff
Re: How long does it takes to re-add the same user/email after being removed?
Hi NGS,
Thanks for your post!
Since the user account still exists in the TeamViewer database, although removed from your Company Profile, please use the Add Existing Account option in User Management to add the account back to your license.
Hope this is helpful.
Jonathan
Highlighted
Posted by
Photon
THIET LAP TU **bleep** CHO TOI
Highlighted
Posted by
Photon
We have the same query but to add to it is that the we cant add the user as it asks to be added to trusted device and the user does not get the email.
Hence the user is stuck as we are unable to add him back nor is he and neither will the email from Teamviewer auto sending link reach his/her mailbox
