Remote access not working on asus devices even after latest update..
Announcements
First Step Guides
  1. Are you new to TeamViewer and Home Office and need some help? Check out our FAQ here.
  2. New to the Remote Access Plan? Find our first steps FAQ here.
  3. Are you new to blizz and online meetings or classes and need some help? Check out our FAQ here.
Highlighted
Posted by
Henagon
So, i have 2 asus phones..asus zenfone 5z and max pro m1..tried running host on both these from samsung a8(2015) after installing the latest versions as of today of TeamViewer and TeamViewer host but could only view screen..no remote control working..also tried host on samsung and TeamViewer on asus and that works fine...pls suggest solution..
Highlighted
Posted by
Digon
Re: Remote access not working on asus devices even after latest update..
I have a Zenfone Max Pro M1 phone that I want to control via Q/S. I installed Q/S from Play Store this morning. Q/S installs fine and surprisingly does not ask to install an addon. I tried and can connect to the phone from both another Android phone and my Win10 PC. I can see the phone's screen no problem. But when I try to remote control the phone by clicking anything all I see is a blue hand/finger appear. No event is generated at all. I found an Asus addon in Play Store and installed that as well to see if it made any difference. It does not. What is up with this? Thanks
Highlighted
Posted by Moderator Moderator
Moderator
Hi @Whitedavidp and @rpt89ryt ,
thanks for your posts. Could you please check in your phone settings that remote access is allowed for Quicksupport?
Thanks in advance for your answer
Have a nice afternoon, Alena :)
Spanish Community Moderator
If my reply answered your question, help out other users and click the Accept as a Solution  button below. You can also say thanks by clicking on the Thumbs Up button!
English Community |  Deutsche Community | 日本語コミュニティ |  中文社区 | Communauté française | Comunidad española
Highlighted
Posted by
Digon
Hello and thanks.
When I first installed Q/S I was prompted for and granted permission to write over other apps.
I have looked around and not managed to find any remote access permission you mention. Can you please elaborate about where to find and enable it?
Highlighted
Posted by
Henagon
Thanks for your reply @AlenaC,
I cannot find the permission for remote access. I did grant the permission it asked (drawing over other apps) in the beginning.
I have add-on for Asus,
I can control other Android phone but cannot let my phone be controlled by other devices.
