Service Fails To Start on Boot (works fine after manual start as ASdministrator)
Highlighted
Posted by
Photon
The service will not start on boot. >> Service is shown as automatic but is stopped immediate after I boot. >> Have enabled it in options but no luck. >> Tried delayed start but no luck >>Have tested service with compatibility tool and rolled back to win 8 but no luck. >>Then after boot if I start manually everything is normal. >> Any ideas what has changed? >>Worked for years just fine. >>This is on Old Dell I5 with Win 10 AE. >> Best Regards
Highlighted
Posted by Community Manager
Re: Service Fails To Start on Boot (works fine after manual start as ASdministrator)
Hi gt40,
Do you still have the issue or is it working again?
Find this helpful? Say thanks by clicking on the Thumbs Up button. Find more information here: Knowledge Base | Community Blog | How to get started
Highlighted
Posted by
Photon
I face the same issue. I haven't found any solution. Can someone please help? Thank you.
Highlighted
Posted by
Photon
I have the same issue...
In the Windows Event Log there is an error that the TeamViewer service didn't start within 3000 ms.
