Announcements
Shape the future of your TeamViewer product with our Product Team. Click here to join!
Posted by IT-Ops-Team
Photon
TeamViewer vulnerability to access *any* system with TeamViewer installed?
Hi Team Viewer Team,
As a customer of yours, can you please confirm if the below Vulnerability has been mitigated or not yet?
https://meterpreter.org/fireeye-apt41-compromised-company-behind-teamviewer-which-enabled-them-to-ac...
Because it is quite serious and can result in a privacy breach & trust issue in the business.
Thank you in advance.
1 Reply
1 Accepted Solution
Accepted Solutions
Posted by Moderator Moderator
Moderator
Solution
Re: TeamViewer vulnerability to access *any* system with TeamViewer installed?
Hi @IT-Ops-Team ,
TeamViewer is safe to use. FireEye has made clear that they are not implying a compromise of TeamViewer or a previously undisclosed incident.
See our statement in the TeamViewer Community from here.
Yuri
View solution in original post
1 Reply
Moderator
Solution
Hi @IT-Ops-Team ,
Yuri
