Windows inverted system scheme for mouse not working with actual colour
Highlighted
Posted by
Henagon
windows inverted system scheme for mouse not work with actual color.
windows have inverted colour mouse pointer scheme but after applying it teamviewr shows transparent pointer which is unvisible. I am using inverted system scheme from many time but by TeamViewer i can't see my pointer. This irritat me. And at last i have to change the scheme. Please solve it.
VikRaj
Highlighted
Posted by TeamViewer Staff
TeamViewer Staff
Re: Windows inverted system scheme for mouse not working with actual colour
Hi VikRaj,
When connected to a remote device, TeamViewer will mimic the mouse pointer in the remote end when the mouse is hovering over the connected window. At the moment, I do not know of any way to disable this as it is a built in feature of the software.
Can you please clarify the issue? Was the inverted mouse colour scheme applied on the remote computer or the computer you are connecting from? Also, is the remote computer a touch screen device? (As these often have an invisible pointer TeamViewer will mimic)
-Scotty
Senior Moderator
Highlighted
Posted by
Henagon
I am using my Laptop as remote device. OS Windows and no touch screen. I am controling my pc from My android mobile phone with TeamViewer 12.
In my PC. i set
 In Windows pointer lookes as image showing below
In Mobile pointer lookes as image showing below
Transparent Pointer with Black border.
TeamViewer don't mimic the mouse pointer in the remote end.
VikRaj
Highlighted
Posted by
Henagon
I have the same issue, it's really annoying.
