Highlighted
Posted by
Henagon
Problem downloading Teamviewer 14 for Linux
I have been using TeamViewer since 2014 on the various Windows OS's.
I am now trying to install it on the current openSuse Tumbleweed .
I have tried numerous times to download Teamviewer 14. It seems to download Ok, but when I go to install it I get a msg that states:
Package teamviewer-suse is broken, integrity check has failed.
The file is:
teamviewer-suse_14.6.2452.x86_64.rpm
and is 13.3 MiB in size.
I have marked it executable in file properties.
I find no place on Teamviewer that shows md5, sha-1 sha256 checksums that I can check the downloaded file.
Can someone suggest how I can get this program installed?
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by
Henagon
Solution
Re: Problem downloading Teamviewer 14 for Linux
Thanks  rolandg,
Where on the teamviewer site are the checksum's listed?
It was Yast software installer giving the error msg.
I am not too sure what was going on, but I re downloaded teamviewer 14 and tried to install using zypper and after recieving notice of and installing a couple of dependancies, teamviewer has now been installed and is working.
View solution in original post
Highlighted
Posted by
Tetragon
hmm,
downloaded the rpm from the TV website.
teamviewer-suse_14.6.2452.x86_64.rpm    13985544 bytes
sha1  8eee69763591b49813a88f11aa5798e4aa400f05
sha256 66c8b9558a1aeef44285ffe6e7b6c3d83c048a70ef1edba8f8969505def6d348
there is no need to make a rpm file executable.
How are you trying to install the rpm (zypper, rpm, ... ) ?
which tool reports 'integrity check failed' ?
Are you aware of
https://community.teamviewer.com/t5/Knowledge-Base/How-to-install-TeamViewer-on-Red-Hat-and-CentOS/t...
(first  section only)
br
Roland
Highlighted
Posted by
Henagon
Solution
Thanks  rolandg,
