Highlighted
Posted by pozso123
Trigon
Unable to conenct in LAN network from android device to pc
I cant connect to pc from android TW in same LAN network.. Connection has established but when i enter the personal password, it just loading with " please wait for connection" While the PC show connection has built up, it show the session list open from system try.
my pc have windows 10 pro 1903 build.
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by Senior Moderator Senior Moderator
Senior Moderator
Solution
Re: Unable to conenct in LAN network from android device to pc
September 2019 UPDATE: TeamViewer Remote Control v14.6.236 for Android resolves the issue which prevented LAN connections. Please make sure to update to the latest version to resolve
Hello Everyone,
Thank you for your feedback.
Please understand the Community is mostly user-based - as such, a specific post being "open" or "solved" does not indicate whether or not TeamViewer is internally looking in to or actively working on a resolution for any said issue.
A marked solution is moved to the top of the related thread, ensuring any new users who come across the issue do not have to scroll to find an official response or resolution. As such, this thread is marked as solved as we have indicated that our teams are working on a resolution. As we posted a month ago, while we await the complete resolution, we are able to provide a functional build where the issue does not occur. [link removed - v14.6.236 resolves this issue. Please update to 14.6.236] I have also marked this reply as a resolution, to ensure it appears at the very top so all users can find the download.
Please also know that, as moderators, one of our tasks is to keep the Community organized. Threads and posts regarding the same identical issues or topics can be merged for clarity, especially once a resolution is provided - this way, we need only update one post instead of multiple, to ensure those affected are aware of a potential fix.
Thanks to everyone in this thread for their feedback regarding TeamViewer and your experiences with it, and for being active members in our TeamViewer Community!
Josh P.
Senior Moderator
If my reply answered your question, help out other users and click the Accept as a Solution  button below.
You can also say thanks by clicking on the Thumbs Up button!
Thanks for being an active member of our Community!
Japanese Community (日本語コミュニティ) |  Chinese Community (中文社区) |  German Community (Deutschsprachig) | French Community (Communauté française) | English Community | Spanish Community (Comunidad española)
View solution in original post
Highlighted
Posted by Moderator Moderator
Moderator
Hello @pozso123,
It is technically an expected behaviour that it does not work.
Our entire mobile device solution is cloud-based.
In other words, with TeamViewer, you need internet in order to establish a connection with a mobile device.
You will find more information about our Mobile Device Support solution here: Support of iOS, Android, and Windows Mobile Devices
French Community Moderator
Did my reply answer your question ? Accept it as a solution to help others.
Find this helpful ? Say thanks by clicking on the Thumbs Up button.
Highlighted
Posted by pozso123
Trigon
okay but it still worked with this methode a few weeks ago
Highlighted
Posted by 1aserman
Digon
I agree with pozso123.
This option worked a few weeks ago and now, no longer works.
Something changed on Y'alls end and updated something to where it doesn't work now. Everything was fine. Now, I cannot connect to a local LAN connection either.
I've been providing feedback with no feed back regarding this. I'll provide further logs if you need so you can see the errors I've been getting, if necessary.
Highlighted
Posted by 1aserman
Digon
Jean,
Hope you can see my post below but this option doesn't work for me any more either.
I used to be able to connect on a local LAN but no longer can.
1aserman
Highlighted
Posted by iFarid
Neutron
I have same problem in Andriod. Local LAN connection works fine on iOS, but not on Android.
Highlighted
Posted by iFarid
Neutron
Dear @JeanK
This is not an excpected behavior. I have an iPhone and the Local LAN connection works perfectly, however on Android it's loading forever without connecting as the other user said. I don't know who put you as Moderator here. Please don't think users are stupid.
Forward this bug please to someone with techinical knowledge who can fix the android version of TeamViewer.
Highlighted
Moderator
Hello all,
Hello @iFarid @pozso123 @1aserman
Thank you for your messages.
First of all, I would like to apologise for my answer past Thursday. I have gave a wrong answer to it. It is possible to make connections from an Android to a computer using a LAN network. I am sincerly sorry about it, and hope this won't damage the trust between us, Community moderators, and you.
We have been testing with our Community Support Engineer @Julia and trying to reproduce this issue internally on our local network.
We found out, that (as mentioned by @pozso123 and @1aserman) it worked fine with older versions of the app and didn't work with the latest app. We noticed the same symptoms as described in the screenshot of @pozso123.
We have forwarded this issue to our development team. They are now working on a fix.
I would like to thank you for having been so reactive. This accelerated the process and we will keep you updated about the fix.
Sorry again for my mistake.
Highlighted
Posted by Fredster
Henagon
Teamviewer 14 issue with Teamviewer Remote Control
I have been using Teamviewer Remote Control on my Android mobile phone for a long time to connect to my desktop PC without issues. I connect with an IP address, using the connect over LAN feature. This worked great until recently.
Recently when I entered the desktop PC's IP address to connect, the Teamviewer Remote Control shows 'External connection' and prompts my password. After entering the password successfully, a message displays 'Please wait while connecting'.
The PC screen background changes to black and the Teamviewer panel on the right is displayed.
However, on my mobile phone the desktop PC screen does not appear.
If I exit//close the Teamviewer Remote Control or Teamviewer desktop program, then I receive a confirmation the connection was ended and a message thanking me for using Teamviewer.
When using my Teamviewer Partner's ID to connect (over an internet connection) I could connect successfully. But, I want to connect over my LAN.
I uninstalled the Teamviewer Remote Control on my mobile phone and Teamviewer 14 on my desktop PC.
I then downloaded previous versions of both programs - Teamviewer Remote Control v13 (TeamViewer.apk) and Teamviewer Windows v13.2.36215 (TeamViewer_Setup.exe) - and installed Teamviewer Remote Control v13 on my mobile phone and Teamviewer v13.2.36215 on my desktop PC.
The result was that my Teamviewer Remote Control connected successfully to my desktop PC using the IP address and over LAN connection. I could see and control my desktop PC from my mobile phone.
I then updated my Teamviewer Remote Control on my mobile phone to the latest version 14.3.198 CL. I could connect successfully again to my desktop PC.
Then I updated my desktop PC's Teamviewer to the latest version Teamviewer v14 and experienced the same issue as at the top, of not being able to display my desktop PC screen on my mobile phone.
Needless to say, I uninstalled Teamviewer v14 on my desktop PC and reinstalled Teamviewer v13, to have access to my desktop PC.
Thus, there is a connection issue between the Teamviewer Remote Control Android App and Teamviewer v14, which prevents the remote desktop PC to display on the Teamviewer Remote Control Android App.
Can this issue please be fixed?
Highlighted
Posted by GreasedMonkey
Digon
Hi. The last response to this was 2 weeks ago. I'm still getting the same error on my Android device. Has there been any resolution to this? Or let us download the older version of the app please?
Highlighted
Posted by x_simon
Trigon
The app on the play store has been updated, but the issue on local connections from android persists (works fine when the client it's a win10 machine)
Highlighted
Posted by 1aserman
Digon
Dear @JeanK
It's been over a month now, and wondered has anyone come any closer to resolving this? Local LAN Connections are still not going through.
Laserman
Highlighted
Posted by pozso123
Trigon
Use "**Third Party Product**" android and windows version till this time. This is able to do it without issue.
Highlighted
Posted by dhamijad
Henagon
What is the name of the third party application?
Highlighted
Posted by dhamijad
Henagon
Great! Thank you!
Highlighted
Posted by x_simon
Trigon
May I also ask you about an indirect reference to a working client? Thank you in advance.
Highlighted
Posted by Elessar12
Photon
Any update to this issue??
It's really making it hard for my to do anything with my phone. I rely on connecting via LAN remotely using a VPN (for security reasons) and right now it's causing some issues.
Highlighted
Digon
Hi guys, I found an older version of Teamviewer and it still works with connecting to other computers over LAN. You can use this in the meantime first, then install the one from the Play Store later on, once they've fixed the issue. You should uninstall the one from the Play Store first before installing this one.
Here's the link to it: [external link removed per Community Guidelines - Please do not download TeamViewer from unauthorized sources]
Highlighted
Posted by x_simon
Trigon
If only the developers could work as fast and as well as the moderators.. the problem would have been already resolved.
They monitor the operations and they exclude a potential issue (for security).
Highlighted
Senior Moderator
Hello Everyone,
Thank you for your posts and feedback.
Our teams are working diligently to resolve this issue.
While we await the complete resolution, we are able to provide a functional build where the issue does not occur. You can find it here.
We thank you for your patience and understanding.
Josh P.
Senior Moderator
Highlighted
Posted by x_simon
Trigon
Tried to install it but, even allowing Chrome to install from unknown sources the setup, shortly after starting, ends with Unable to install.. (Huawei P20, Android 9)
Highlighted
Posted by x_simon
Trigon
Still no updates about this issue, am I right?
Highlighted
Digon
Yep, no updates and still doesn't work.
Highlighted
Posted by x_simon
Trigon
Exactly, not with official client, not with the one provided here.
Highlighted
Posted by pozso123
Trigon
Sure, in The development team task calendar it is not a major bug which demand fast action, therefore they postpone this fix on other date of release.
Do not wory, nobody from the developper team give priority for this post in this forum.
Highlighted
Posted by Alitai
Trigon
Connection from Android 9 to Windows 10 1809 crashes App
Hi Together
I had a lot of fun the last Year with Teamviewer. Everything worked fine. Until now.
Both Clients are on the same Network. I connect over IP.
After i type the PW on Android the App crashes or say "Connection, please wait" forever.
All updates are installed. This worked always for me but now i have no idea why not. TeamViewer on Windows says connection established so that works but i don't get a Picture on Android.
Does anyone know this Problem?
I saw this one:
https://community.teamviewer.com/t5/Mobile/Unable-to-conenct-in-LAN-network-from-android-device-to-p...
but this is for Windows 1903 and not 1809.
Many Thanks
Best Regards
Alitai
Highlighted
Posted by Alitai
Trigon
What's matter is that they know about, communicate that and also say that they will fix it.
Highlighted
Posted by Alitai
Trigon
Re: Connection from Android 9 to Windows 10 1809 crashes App
Can confirm it's the same Problem but just for Windows 10 1809.
Can't delete this Post...
Alitai
Highlighted
Posted by x_simon
Trigon
In the meantime I've lowered my PlayStore review to ONE star.
Highlighted
Posted by x_simon
Trigon
New update, new failure to resolve this issue. The topic instead has a large "Solved" tag.
Highlighted
Posted by Alitai
Trigon
Can confirm. Still the same Problems as before.
Highlighted
Posted by x_simon
Trigon
Unable to connect from android to win 10 using local address
Similar topic marked Solved without any working solution.
Highlighted
Posted by x_simon
Trigon
Started a new topic because this one was already marked as Solved.
Highlighted
Digon
Re: Unable to connect from android to win 10 using local address
Adding my voice to this too because Teamviewer seems reluctant to solve this. Maybe it's because they want ALL connections to go through their server?
Highlighted
Posted by Alitai
Trigon
@x_simon Where is this new Topic? Can't find it.
@GreasedMonkey Yes, i think too. All Cloud.... :( This is also open a long Time now (https://community.teamviewer.com/t5/Mobile/Teamviewer-Host-on-Android-using-local-ip/m-p/70024#M2703). Same thing.
Highlighted
Posted by x_simon
Trigon
They moved my new topic in this thread (the one without the "Re" tag), so it's under a Solved tree and they haven't any open issue.
Highlighted
Posted by x_simon
Trigon
Ah, the post you've linked it's also marked.. wait I double check.... SOLVED.
Highlighted
Senior Moderator
Solution
Hello Everyone,
Josh P.
Senior Moderator
Highlighted
Posted by x_simon
Trigon
Sadly the build provided is not functional.
Highlighted
Senior Moderator
Hello @x_simon
Thank you for the clarification.
I had not seen any indication of this prior. I will let our teams know and reply once I know more regarding our temporary solution.
Josh P.
Senior Moderator
Highlighted
Senior Moderator
Hello Everyone,
Thank you for your patience.
We have tested the linked APK on a few devices, including Huawei other manufacturers, and did not encounter any issues during installation. Any errors encountered may indicate a device-specific issue.
Let us know if any issues installing the temporary workaround persist.
Josh P.
Senior Moderator
Highlighted
Digon
Hi Josh,
The issue is not in installing the APK, but rather that the feature of connecting to a computer via local area network still doesn't work with that APK file. It worked once before, when I first installed it, but failed in all other efforts afterwards.
Highlighted
Posted by xhen
Digon
I tested today from my android device to a linux computer in the same LAN:
I entered the IP address of the laptop and click connect, ask me for the passsword, and after entering the application closed abrutly , no error, no message, just closed.
So still not work. latest version in both devices
Highlighted
Posted by classpath
Henagon
Same here. I have used LAN connection from Android to PC more than two years, especially on off-internet - local LAN only - environment. But as described by other users, it stopped working suddendly.
I have a version which was release by Aug 15, 2019. My phone is Google Pixel 3.
Highlighted
Posted by Alitai
Trigon
Works again!!!!!!!!!!!!!
Thanks so much TW!!!!
Regaaaards
Alitai
Highlighted
Senior Moderator
Hello @Alitai
That is correct! The latest version of TeamViewer Remote Control for Android was just released, and contains the full resolution.
Anyone still affected should update to this version.
Changelog is here: https://community.teamviewer.com/t5/Change-Logs/Android-Remote-Control-v14-6-236-Change-Log/td-p/719...
I have also updated the solution to the article to reflect this.
Josh P.
Senior Moderator
Highlighted
Posted by 1aserman
Digon
I will make the update today. Thanks for the efforts and look forward to a working copy of this.
laserman
