Team viewer not working more than 5 min ,even after login with registred user. only work on teamvier
Announcements
Remote Control for all devices running Android 7+ is here!
(Incl. Google Pixel series, Xiaomi smartphones, Oppo devices, and many more)
Learn more
Highlighted
Posted by
Photon
i am facing problem with Team viewer New versions, i have company registred account which works fine with teamviewer 10 , but if i upgrade my team viewer to 11 or 12 i am getting message that i will have 5 min only to remote connection. and it disconnects as per said time and will not connect again.
what could be the issue ,
1 Reply
1 Reply
Highlighted
Posted by TeamViewer Staff
TeamViewer Staff
RE: Team viewer not working more than 5 min ,even after login with registred user. only work on
Dear @omer
Could it be, that your company had bought a license for TeamViewer version 10?
It sounds like your account is activated with this license. If you make an update to a higher version on your local TeamViewer you start a trial period.
If this trial is expired, it might be that you have interruptions during the connection.
For commercial use your company needs an update to version 12. Our salesteam will be pleased to provide you with a specially offer.
If required, please contact our salesteam here
Best regards.
Reyhan
