Good morning. Yesterday when I connected to a PC using Teeamviewer I got this message
Important Notice: update the remote TeamViewer
Please make sure both sides are running a newer version, old versions will be discontinued soon.
On that PC it's installed Teamviewer 10. I connect using my PC that has teamviewer 15 with a corporate license
I checked the link in the popup message and saw the post about the discontinuation of server support for versions from 8 to 10 on September 15 2021. Does this mean that before that date I will have to update the teamviewer version client side to version 15, otherwise I will not be able to connect to that PC at all?
