Hello Community,
I cannot get to my destination with a remote connection between two smartphones.
I would like to set up a Samsung S21 Android 11 as a controlling smartphone and a Huawei P20Pro (Android 10) as a controlled smartphone.
I install Teamviewer on the S21 and the Teamviewer Host app on the Huawei with the additional required universal add-on.
I have created an account, which I enter in the required fields in the Huawei. The account and everything else is set up on the S21. Now
I have the following problem.
I would like to control the Huawei from Germany, it is not in the same place. If I want to establish a connection,
I have to open the "HOST" app on the Huawei because it is not automatically loaded after a restart, for example, even in the I have to bring the host app first.
Next, when both are green, I'll connect. As soon as the connection is established, a message appears on the Huawei: "Host is recording all activities displayed on your screen. (Cancel or Start now).
If I confirm this, the connection will only be established.
But that's not what I mean by an unsupervised connection.
In addition, the Samsung S21 can control from nothing.
At the time I am about 1000 km away and cannot confirm the button.
Any a idea???
