Where is tzhe problem.
I`m using 10 PC`s in my private network and i can connect to all these PC`s - except the PC number 5. After a remote update the connection doesn`t work. Always get the message: Initailizing Display Setting" - that`s it.
I reinstalled Teamviewer a couple of times (on both sides) - always the same. I also checked some forum entries, but unfortunately no solution found.
What can i do?
thanks a milli0on in advance
regards
Martin
