I used to get the system audio from the remote PC . For some reason I no longer get it. The audio is on on the remote and the speakers are up on the local PC.
Did this change with one of the updates?
Nor
HI Justin,
Am running widows 10 pro. I got it to work
Thanks.
Hello @njsg,
Would you tell me what operating systems you're currently using?
Justin
