I am new to TeamViewer. How do I connect to my home computer while traveling on the road from another city in the USA? I don't know how this all works! Thank you.
Hello @CraigOchoa123_
Welcome to TeamViewer and our Community!
By default, to start a remote session, you must know what is the partner's ID and Password.
If you want to have access to the device at any moment, you need to configure the easy access.
However, If you are currently far away from the device that you want to connect, and you never configured easy access, my suggestion is to call someone who is close to it, and:
Once your are connected, you can set up the easy access if you want.
Please let me know if it helps and if you have any further questions 😊
.Carol.fg.
