We are currently (still) using Teamviewer 11 within my team in order to support a customer who also uses 11. It recently occured that one of the team members who has 11.0.XXXX installed wanted to connect to a customer with client version 11.0.XXXX received a message that the connection is not possible due to the customer running a higher version of Teamviewer.
My question is: Shouldn't all connections between ANY Teamviewer 11 sub-version be supported and only connections to higher versions such as TV 12-15 be blocked?
Thanks in advance for clarifying!
