I installed teamviewer (15.26.4 (RPM)) on Fedora35. After steps below, no window/GUI appear.
$ sudo teamviewer daemon enable
Wed Feb 2 02:51:56 PM PST 2022
Action: Installing daemon (15.26.4) for 'systemd' ...
installing /etc/systemd/system/teamviewerd.service (/opt/teamviewer/tv_bin/script/teamviewerd.service)
Try: systemctl enable teamviewerd.service
Created symlink /etc/systemd/system/multi-user.target.wants/teamviewerd.service → /etc/systemd/system/teamviewerd.service.
systemctl start teamviewerd.service
Wed Feb 2 02:52:04 PM PST 2022
$ teamviewer
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
# and teamviewer gets stuck here.....
# while I run "teamviewer" in a new shell window
$ teamviewer
Init...
Checking setup...
# The initialization looks completed, but still no window appear.
$ teamviewer info
TeamViewer 15.26.4 (RPM)
grep: /opt/teamviewer/config/global.conf: Permission denied
TeamViewer ID:
Try restarting the TeamViewer daemon (e.g. teamviewer --daemon restart)
teamviewerd status ● teamviewerd.service - TeamViewer remote control daemon
Loaded: loaded (/etc/systemd/system/teamviewerd.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2022-02-02 14:51:56 PST; 1min 43s ago
Main PID: 8446 (teamviewerd)
Tasks: 22 (limit: 9107)
Memory: 4.6M
CPU: 478ms
CGroup: /system.slice/teamviewerd.service
└─8446 /opt/teamviewer/tv_bin/teamviewerd -d
Feb 02 14:51:56 localhost.localdomain systemd[1]: Starting TeamViewer remote control daemon...
Feb 02 14:51:56 localhost.localdomain systemd[1]: teamviewerd.service: Can't open PID file /run/teamviewerd.pid (yet?) after start: Operation not permitted
Feb 02 14:51:56 localhost.localdomain systemd[1]: Started TeamViewer remote control daemon.
Feb 02 14:52:04 localhost.localdomain systemd[1]: /etc/systemd/system/teamviewerd.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /run/teamviewerd.pid; please update the unit file accordingly.
Any ideas? Thank you very much.
