How to remote a Pc 64-Bit on 32-Bit via Teamviewer?
Hello @Berny915,
All you need to do is to:
Install the 64-bit version on the 64-bit PC and the 32-bit version on the 32-bit PC.
The connection should work fine.
JeanK
Thank you for the answer!
