for a few months I am seeing that if I connect to a remote computer, and then ends this connection, a TeamViewer process will continuously run on the host, using 25% of the CPU. Only way to get rid of it is to kill it. Completely exiting TeamViewer might to the job though.
The way I found out was because with a 25% CPU process, my laptop fan will start making noise :-(
I did not have this behavior in the past.
Is this a known issue ? A query on Google / this forum did not return anything relevant.
Thanks for your help.
