Hi, I’m a student and I need a power computer. I looked for a laptop but they were very expensive! Can I buy a power pc for my home and use it at school with teamviewer with a budget laptop?
thank you!
Hello @Wolfhelo,
Using TeamViewer does not require much performance. Therefore, yes, you could use the software with a budget laptop.
However, we cannot advise you which computer you will buy. For this, you might check what would suit your budget and needs on the internet.
Hope this helped!
/JeanK
