Teamviewer Timeouts and connection established after several retries
Hello Community,
like the Title says, we have a problem with our Hosts, we get an Timeout for several connections until we can connect on the devices, below i paste some of the logs:
2022/07/27 09:00:11.298 3024 2396 S0 Activating Router Carrier
2022/07/27 09:00:11.298 3024 2396 S0 CommandHandlerRouting[42]::CreatePassiveSession(): incoming session via at-vie-anx-r014.router.teamviewer.com, protocol Port443
2022/07/27 09:00:16.314 3024 2396 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Timeout was reached (28), Connection timeout after 5012 ms
2022/07/27 09:00:16.314 3024 2396 S0!! ProxyConnection::RequestFinishedCallback: failed with HTTP status code = 0
2022/07/27 09:00:16.314 3024 384 S0!! CommandHandlerRouting[42]::HandleConnectPassive(): connect failed!
2022/07/27 09:00:16.314 3024 384 S0!! CreateIncomingClassicSession::StartSession: router connection failed
2022/07/27 09:00:43.286 3024 1684 S0 DriverConfiguration::GetPortNumber: No readers available
2022/07/27 09:00:43.286 3024 1684 S0 Activating Router Carrier
2022/07/27 09:00:43.286 3024 1684 S0 CommandHandlerRouting[43]::CreatePassiveSession(): incoming session via de-muc-anx-r010.router.teamviewer.com, protocol Port443
2022/07/27 09:00:48.302 3024 2396 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Timeout was reached (28), Connection timeout after 5006 ms
2022/07/27 09:00:48.302 3024 2396 S0!! ProxyConnection::RequestFinishedCallback: failed with HTTP status code = 0
2022/07/27 09:00:48.302 3024 384 S0!! CommandHandlerRouting[43]::HandleConnectPassive(): connect failed!
2022/07/27 09:00:48.302 3024 384 S0!! CreateIncomingClassicSession::StartSession: router connection failed
2022/07/27 09:01:34.073 3024 1684 S0 DriverConfiguration::GetPortNumber: No readers available
2022/07/27 09:01:34.088 3024 1684 S0 Activating Router Carrier
2022/07/27 09:01:34.088 3024 1684 S0 CommandHandlerRouting[44]::CreatePassiveSession(): incoming session via de-muc-anx-r007.router.teamviewer.com, protocol Port443
2022/07/27 09:01:39.104 3024 384 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Timeout was reached (28), Connection timeout after 5015 ms
2022/07/27 09:01:39.104 3024 384 S0!! ProxyConnection::RequestFinishedCallback: failed with HTTP status code = 0
2022/07/27 09:01:39.104 3024 1684 S0!! CommandHandlerRouting[44]::HandleConnectPassive(): connect failed!
2022/07/27 09:01:39.104 3024 1684 S0!! CreateIncomingClassicSession::StartSession: router connection failed
2022/07/27 09:02:57.691 3024 384 S0 DriverConfiguration::GetPortNumber: No readers available
2022/07/27 09:02:57.691 3024 384 S0 Activating Router Carrier
