I can't connect to a PC from an android device (tried 2 devices). I'm located in Ukraine. Can anyone answer me why the TeamViewer doesn't work? Is it a problem only in Ukraine or elsewhere?
Hello @Va1er4ik,
Great to see you posting for the first time! 🙌
There are currently no connectivity issues reported in Ukraine. Therefore, I would assume that the issue is device-related.
Are you getting any specific error messages when connecting? Can you describe what is happening?
/JeanK
