I have been using TeamViewer for a long time, and after updating to the latest version 15.37.3 (64bit), drag and drop no longer works. It doesn't work from the host to the remote PC, and it doesn't work from the remote PC to the host. All systems have the same version of TV installed on them.
Drag and drop is enabled (not disabled). I've been using these same settings since TV 13, and it's always worked before. Is there any fix for this?
