Hello. I have 2 questions:
1)
Which versions should I use if I want to control my Android device via my PC (or another Android) ?
2)
How to avoid the popup, which asks to Autorize per every connect? I need the full automation.
Hi, should i also install the TeamViewer Universal Add ON ?
thanks
Hi @VarKar,
For the remote connections from a PC or mobile device to a mobile device, I have listed suggestions below:
Initiator - PC: TeamViewer Full client
Mobile: TeamViewer Remote Control
Receiver - Mobile: TeamViewer QuickSupport or TeamViewer Host
TeamViewer Host is recommended this time as it would ask for the setup of account assignment at the beginning of the connection and you may connect the mobile device via Host without any further confirmation.
Give it a try and keep me posted about your progress.
