I saw that there was a maintenance update around midnight today. Since then I cannot connect. Everything is fine from both ends .
Hello @sld0728,
Welcome to the Community!
There was a scheduled Maintenance on the past weekend, which was completed on time. You may check out the TeamViewer Status page for the full update about this maintenance.
If you still can't make any remote connection now, we would like to suggest you restart TeamViewer services on both sides of the remote connection and see if it helps to improve the connection.
