Hi. I've updated my raspberry pi4 with a fresh installation of the latest Raspbian OS Bullseye, and then I've installed the latest Teamviewer version for it.
I'm experiencing a tremendous laggy response when I control my raspberry, and a strange screen behaviour (as the screenshot above): though the screen is correctly displayed, the teamviewer's corner banner stays as in the picture as if it doesn't recognize the correct desktop size/resolution and it treats the space as a 640x480 display.
I've also VNC remote running on the system with the display size of 1920x1600 in case of headless use.
Another problem is that the most of times I'm connecting to my raspberry with Teamviewer, it freezes immediately, so I have to close the connection and try again.
Could you help me solve these problems? Thanks!
